Gold Member Username: LexuscoopPhx, Arizona Post Number: 1361 Registered: Dec-05 | does anyone know of a song that tests every lvl of frequensy? (sub frequensy) because i want to see how my subs do on all Hz, you know? idc if the song doesn't have a beat, or a rythem, i just want to know what my subs sound like on all sub frequensy's Thanks |
Gold Member Username: Young_jamesCanada Post Number: 1286 Registered: Sep-05 | go to ROE, downloads and pick your choice......or go out and buy bass mechanick |
Gold Member Username: LexuscoopPhx, Arizona Post Number: 1362 Registered: Dec-05 | ROE? idk what that is |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 612 Registered: Jan-05 | Realm of Excursion www.realmofexcursion.com |
Gold Member Username: Young_jamesCanada Post Number: 1287 Registered: Sep-05 | realm of excursion http://www.realmofexcursion.com/ |
Gold Member Username: LexuscoopPhx, Arizona Post Number: 1363 Registered: Dec-05 | thanks guys |
Gold Member Username: Young_jamesCanada Post Number: 1291 Registered: Sep-05 | no prob |
Silver Member Username: WinterfreshpimpChisago, MN America Post Number: 172 Registered: Mar-06 | listen to track 3 on t.i.'s cd its hits alot of different notes and its a good song |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 101 Registered: Nov-05 | can test tones hurt ur sub or amp or anything in any way? cuz i want to test mah subs frequency and see the xmax.. which tones should i download? also wat vloume should i play these tones at? heres a few.. 35Hz to 50Hz Sine Sweep 35Hz to 1Hz Sine Sweep 60Hz to 70Hz Sine Sweep 60Hz to 45Hz Sine Sweep 100Hz to 20Hz Sine Sweep 250Hz to 20Hz Sine Sweep 22kHz to 1Hz, 1Hz to 22kHz 20Hz to 120Hz Slow Warble 40Hz to 80Hz Slow Warble 30Hz to 50Hz Medium Warble which should i use? |
Silver Member Username: FiberPost Number: 179 Registered: Mar-06 | well if you want to test almost all of them fo 250Hz to 20Hz 20hz is as low as the human ear can hear and 250 sounds like a high pitched toot... |
Gold Member Username: Basshead86Slowcala, FL The one that... Post Number: 2936 Registered: Aug-05 | they can only hurt if you turn it up too loud and the sub bottoms out, or the amp clips the signal. |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 104 Registered: Nov-05 | so if i use that one jus keep the volume around 15-20? |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2663 Registered: Sep-04 | if your amps are tuned correctly you can play any test tone at full volume (volume you tuned at) as long as it is recorded at 0db. which ROE has. they also have -3db and +3db if i remember right... but you'll want a 0db tone. when i had my avalanche i would play a 20hz tone and my door panels would shake bout half an inch. also make note that if your box is ported yoru SSF must be set right. you dont want to over excurt your sub. |
Bronze Member Username: Blk02ssPost Number: 50 Registered: Feb-06 | that all depends on the HU, and how much your power your giving your subs. |
