Bronze Member Username: Kyuhl22222Post Number: 17 Registered: Apr-06 | will someone please pick out what i should pick for my system, i definately want it loud but SQ also, not for comps 2 12" l7s 2 ohms 2 12" l7s 4 ohm Thunder 1501D (if i can find good deal) sx1250 or kicker 1500 but trying to keep it under 450 orion 1200 DIAMOND D61500.1 any amp you reccomend sealed box ported box if ported tuning of ported box thanks |
Bronze Member Username: Kyuhl22222Post Number: 18 Registered: Apr-06 | i have a 95 2 door tahoe if that means anything |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 920 Registered: Oct-05 | 2 l7 (4 ohm) orion 1200d (wired to 1 ohm) ported box tuned to 30-35 |
Silver Member Username: HighstonePost Number: 149 Registered: Mar-06 | i'm no expert but i would go with the following: 2 12" L7s @ 2ohms Kicker 1500 - OR Hifonics due to budget and finally i will go with ported box, because ported boxes give about +3 db than the sealed tuned at 33hz(not so confident bout the tuning) |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 925 Registered: Oct-05 | for the amp it would be kicker kx1200.1 or the orion 1200d with the 4 ohms subs wired to 1 ohms, ported tuned to 30-35 |
Bronze Member Username: Kyuhl22222Post Number: 19 Registered: Apr-06 | together the 2 l7s will be 1500 rms, will a orion 1200d give enough power |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 931 Registered: Oct-05 | i was thinking that the rms was 1200 altogether. try a http://cgi.ebay.com/HIFONICS-BXI1606D-1-600-WATT-D-CLASS-MONO-AMP-NEW-2006_W0QQi temZ9716298725QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or maybe a hifonics bx2005 because hifonics amps are a lil overrated power wise. |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 932 Registered: Oct-05 | i would get this: http://cgi.ebay.com/HIFONICS-BX2005D-BRUTUS-2000w-MONO-CAR-AMPLIFIER-AMP-NR_W0QQ itemZ9713971015QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: RovinTrinidad & T... Post Number: 7500 Registered: Jul-05 | y r u even getting L7 subs if ur concerned about some SQ ? y not choose some better subs , maybe the CVX which is said 2 have better SQ than L7 subs ...... |
Gold Member Username: RovinTrinidad & T... Post Number: 7502 Registered: Jul-05 | if u wanna keep it kicker that is ^^^ |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1557 Registered: Jun-05 | ya rovin is right those will not have any sq at all so get a round sub if you want tit to lok good go for the cvx'x or maybe some type r's or aa arsenals for the money for those u cant go wrong they all get loud and sound good |
Bronze Member Username: Kyuhl22222Post Number: 20 Registered: Apr-06 | so since i am an everyday driver and im not alll about the loudness i should shy away from the l7s. People are obviously against those on this website i guess they arent worth buying. im looking ot spend 450-500 on 2 12" so which are the highest reccomended. |
Bronze Member Username: Kyuhl22222Post Number: 22 Registered: Apr-06 | so since i am an everyday driver and im not alll about the loudness i should shy away from the l7s. People are obviously against those on this website i guess they arent worth buying. im looking ot spend 450-500 on 2 12" so which are the highest reccomended |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 524 Registered: Dec-05 | i would buy two RE or treo and ED nine 1 |
Gold Member Username: RovinTrinidad & T... Post Number: 7514 Registered: Jul-05 | yep ^ - 2 12s RE SE www.reaudio.com & a RE 1200 amp or Ed9 amp ... http://edesignaudio.com/category.php?type=amps |
