Newbie Has Questions, w/pics
Username: Wnyzfinest
I bought this dish. Dealer Said it was a DISH LEGACY, I dont know..
http://img285.imageshack.us/img285/92/s40220592aj.jpg
http://img137.imageshack.us/img137/7017/s40220611oq.jpg
http://img137.imageshack.us/img137/5940/s40220626va.jpg
I dont know if any one is familiar ,, i Paid $99 I dont know if it's a Good Buy,,,
Now the dealer said I can Run 1 Cable directly to PANSET 2500 ,, but when I did that I only got 1 Sat, now When I use the Panset DSq switch , I connect both 110 and 119 on 1 and 2 and it helps a bit more, but i lost certain channels which used to work any suggestions
Username: Lklives
Post Number: 2151
U cannot use it for any Pansat or any FTA receiver unless coo*lsat or viewsat..that dish has a TWIN Legacy LNB which is NO good for FTA receivers, except noted..If U had Dishnet receivers with cards it would be fine...U need to replace that LNB to a TWIN Dish Pro..
BTW...dealer lied to U..can run 1 cable to Dishnet receiver...not Pansat or most FTA receivers..and U paid way too much, unless NEW in box..!..U paid double... $50 for used..
so then that would be the cause I have the dish connected to the disq switch , I get quality but bad channels
Because I had alot of channels preloaded on reciever it worked but wen I started playing around with wiring because some Channels were coming up,
With the DISH PRO DUAL LNB over a DISH 500 it would work great with a PANSAT 2500 correct..
Thanks Guys!
