Bronze Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 96 Registered: Mar-05 | i am going to build a ported box for my friend. his sub is an orion c series 10 inch and on the website it says to make a .85 cubf box tuned to 50 hz. i dont think 50 hz sounds right what do you think? |
Bronze Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 97 Registered: Mar-05 | bump |
Bronze Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 98 Registered: Mar-05 | bump |
Bronze Member Username: Logan__tilleHamilton, Indiana United states Post Number: 81 Registered: Feb-06 | 50 sounds a little high, dont ya think |
Bronze Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 99 Registered: Mar-05 | yeah thats why im askin |
Silver Member Username: Alexv305Tavernier, FL USA Post Number: 111 Registered: Oct-05 | 35 hz |
Bronze Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 100 Registered: Mar-05 | http://www.accelerator-pedal.com/ported-box.asp?Ew=20&Eh=14&Dia=6&Xmax=11&Vd=.01 6&NumW=1&Vb=&Fb=&Qts=.63&Vas=.68&Fs=41.47&CE=1.5 thats what the calc came up with after i put in all the t/s numbers it seem more reasonable |
Silver Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 101 Registered: Mar-05 | bump |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2639 Registered: Sep-04 | that enclosure will work fine |
