Adding BEV to DN with Viewsat 2000
Username: Carcpl58
Post Number: 33
Already have established DN with 119, and 110 Sat.
Want to Add Sat. 91 with BEV. HAve read that all I have to do is hook cable to Port 3 and scan Sat. 91. Is this true? Can anyone lead me in the right direction on this? I don't want to mess with the DN I alredy have.
Thanks in advance
Username: Lklives
Post Number: 2153
U need another LNB on dish , aimed exactly at 91W...then run cable to disque, eneter Bev keys, scan 91W and then make changes to receiver settings..
Username: Carcpl58
Post Number: 34
Already have a sep. Dsih aimed at 91W so same program that runs DN will work with BEV? Think using 1066 at the moment. Will it not autoroll keys with this program?
Thanks
Username: Lklives
Post Number: 2154
Yes....yes..U are set...cable to disque...add 91W to receiver settings...scan 91w...watch TV
Username: Carcpl58
Post Number: 35
In changing the settings do you mean going into the Antenna (sp) section and changing the LNB and Port settings. I am not too sure about this and don't want to mess with DN settings.
Thanks
