Refurbished
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 610
What is everyones opinion on buying refurbished equipment? esprecially HU's.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 611
bump
Username: Yayo
Post Number: 34
refurbished stuff ussually isnt a good buy.. maybe the odd stuff but dont take the chance.. just spend some money and get some new or hardly used equiptment..theres some great deals on ebay
Username: Juliob
Santo DomingoDominican Re...
Post Number: 514
refurbished= old case with new interior. They're a good buy, if you can save 100$ bucks for the same product, just with "older looks" and same interior brand new, go for it
Username: Redliner
Wilmington, Ma
Post Number: 1523
i just bought a refurbed dd 9512 i dont really see a prob with refurb stuff i obviosly would rather buy new stuff but oh well cant afford the 750 dollar prce tag
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 449
my opinion if it's refurbished... do some research on it before you buy..... make sure it's not a device that seems to break alot... AKA> bad reviews all around... or you seem to be finding the refurbished units EVERYWHERE and in larger quantitys.... as long as this device dosent seem to be Prone to damage than i would buy it.
Username: Young_james
Post Number: 1263
refurbished is great if you don't mind cosmetic faults. Other than that, new insides
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6619
refurbs=new item, old case
Username: Goatin
U.S.A
Post Number: 827
^^ Agreed ^^
I bought my Pioneer 860MP HU a refurb works and looks great.
