Bronze Member Username: EseesaiPost Number: 50 Registered: Mar-06 | my friend is interested in some subs for his '02 camry but hes under a budget and is looking for some subs that have good spl he listens to alot of rap what would u guys recommend? |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 926 Registered: Oct-05 | kicker comp vr's. 2 12" |
Bronze Member Username: EseesaiPost Number: 51 Registered: Mar-06 | how much would the price on those be cause he cant go over i think it was 110 or 120 buck. or if theres a single sub cause he already has a jbl 1200 2channel amp? |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 928 Registered: Oct-05 | look on ebay real quick |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 930 Registered: Oct-05 | http://cgi.ebay.com/Kicker-CVR12-Comp-VR-12-Sub-Woofer-Car-Subwoofer-4-OHM_W0QQi temZ9716907057QQcategoryZ39777QQrdZ1QQcmdZViewItem get 2 of these and wire them to 4 ohms, if his amp puts out 1200 watts @ 4 (which i think it does) |
Bronze Member Username: EseesaiPost Number: 52 Registered: Mar-06 | thats good u guys have any other type of subs? |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1555 Registered: Jun-05 | either that or a alpine type r those 2 are the best bang for the buck but for that price ont he cvr you cant go wrong i would get it now before someone else gets them |
Bronze Member Username: EseesaiPost Number: 53 Registered: Mar-06 | i think its 1200 max ,the amp, and i dont think i can handle 2 of those |
Bronze Member Username: EseesaiPost Number: 54 Registered: Mar-06 | does anyone have any suggestions? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6638 Registered: Jul-05 | post the specs of the amp, and is 120 per sub, or for 2 |
Bronze Member Username: EseesaiPost Number: 56 Registered: Mar-06 | for two and the specs are i think 200rms at 4ohmsx2 then 200 at 2ohmsx2 and 400rms at 4ohmsx1 and 600rms at 2ohmsx1 |
Bronze Member Username: EseesaiPost Number: 57 Registered: Mar-06 | my bad 400rms at 2ohmsx2 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6639 Registered: Jul-05 | look into some infinity kappa perfects(2ohm version) |
Bronze Member Username: EseesaiPost Number: 58 Registered: Mar-06 | do u have a link Chauncey? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6641 Registered: Jul-05 | http://infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12DVQ'&Ser=KPE&Cat=SUB |
Gold Member Username: PelonaPerris, California USA Post Number: 1342 Registered: Dec-05 | wuts the model number of the jbl amp ur talking bout? |
Bronze Member Username: EseesaiPost Number: 60 Registered: Mar-06 | i dont have it but i think its an 02 or 03 model ill check |
Gold Member Username: PelonaPerris, California USA Post Number: 1344 Registered: Dec-05 | the year dont matter pendejo. i think |
