Speaker wire size
Username: Ogduncan
Post Number: 24
What size speaker wire do i need for 1X1050rms @4ohms going into 2 10w6v2
Username: N2audio
Lawrence, Ks USA
Post Number: 806
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Username: Fandim
Reno, Nevada United State...
Post Number: 886
Just use a few coat hangers. :-P
Username: Colinb0080
4ga should handle that power level 2ga or 0 -ga if you plan to add later.
Username: N2audio
Lawrence, Ks USA
Post Number: 811
"4ga should handle that power level 2ga or 0 -ga if you plan to add later"
Thread title:
<b>"Speaker wire size"
Username: Killswitchjd
Post Number: 55
for speaker wire, probably 8 gauge if you can manage it. 10 gauge would be fine as well though...
Username: Ogduncan
Post Number: 26
on the link above it says the difference would be in audible below 12 for my aplication. Or is there something im missing
Username: N2audio
Lawrence, Ks USA
Post Number: 826
nope - 12 is enough
Username: Carguy
Post Number: 5493
Unless you're talking about 1000s of watts, 14 - 16 gauge is fine.
If you can tell the difference between 14 gauge and 10 gauge or lower, then you must be half dog and half human.
Don't get fooled into buying "monster" cables. They're all for shows. Somehow, FutureShop had a setup that demonstrates monster cable vs regular 14gauge speaker wire. The monster cable has more bass and sounds clearer. I know that is a lie, but the idiots shell out $200 for 8 gauge monster cables.
Username: Carguy
Post Number: 5494
correction: demonstrated.
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 638
shut up 200$ for 8ga monster cable...or r u just exagerating......i went to radio shack and bought 8feet of 8ga monster cable for 9$
Username: Fandim
Post Number: 912
So you paid over $1 per foot, for 8 gauge wire.
You could have gotten well over 3x that amount online for wire just as good, if not better.
Username: Carguy
Post Number: 5500
Okay so it was around $189. By the time you add 15% tax on it, it will be $200.
