Find tp's but no channels
Username: Hnic_men
Post Number: 92
hey guys i'm having a little trouble with 121, i have a 2500a with 273bin, since i loaded 273 and tried to blind scan 121 all i'm finding is the tp's but when it scans the tp's it only find about 8 radio channels my lnb settings are feq 10750 standard, u guys think i should load a different channel list?
Username: Lklives
Post Number: 1896
U definitely need new channel list or new scans...many channels have changed satellites...went to spotbeam...and changed TP's..
Username: Hnic_men
Post Number: 93
thanks lk.
Username: Bladam
I am unable to pick up 121, on my pansat 2700, is it likely to get some help.
Username: Bladam
I am picking up 110, and 119, is like to get 121, if please guide me step by step on how to do this, thanks in advance.
Username: Lklives
Post Number: 2011
Guide U?...
get a linear LNB, mount it on a 30 inch dish , put it half in front of the 119 LNB...
now U got 121..
run cable to disque switch..
watch TV...there's your Guide!
Username: Bladam
Thanks LK
Username: Bladam
I was able to pick up echo9, and I did a scan.
but I am getting but I am not getting the 121, but instead I am getting the same channel as 119 is this possible, what am I doing wrong here.
Username: Crippledwarcook
Post Number: 16
LOL...maybe you should stick to cooking and cleaning and let someone that knows what they are doing fix your dish...You are pizzing off the crippled redneck LK by asking all these stupid fcuking questions...ROTF
Username: Lklives
Post Number: 2029
119 is 1/2 inch away from the 121....U can see how the 119 blocks the 121 here...and U got NOTHING on your Echo 9 scan..U're getting the 119 and so did the scan..
Username: Bladam
Thanks Lk, you are the best, your time is greatly appreciated.
crippledWarCook thanks for the insight, but there no such thing as a stupid question, please to forgive me for educating myself here, the days of ladies being barefoot and pregnant are over, so get with the program, don't take this the wrong way I am just keeeping you up to date with the modern world that's all.
Username: Lklives
Post Number: 2036
OH there are stupid questions!...If U asked me how to input the Dishnet keys or load a bin, thats a stupid question because it shows that a LAZY person hasn't read and therefore LAZY and STUPID, and then makes all questions from them STUPID QUESTIONS with simple answers...I hate LAZY people and STUPID questions!...so far, U are OK..
BTW...U are right about women's roles have broadened....but if women want to do mens jobs and be treated equal to a man, then they better be able to take the heat like a man too!...too many women want BOTH sides of the fence...they want their rights and equality, but ONLY want it when its all good, and NOT when times get hard and tough!...thats when they return to their feminine "poor little me" instincts..I give any woman a chance but I never let a woman PLAY me..and I've had thousands of women work for me..
Username: Bladam
LK I understand,you are flooded with all kind of questions on a daily basis, but this is all new to me, your understanding and patients required, on my part. you are doing a wonderful job keep up the good work.
Username: Bladam
Post Number: 7
Username: Bladam
Post Number: 8
Hi my satellite tv is down, is likely there are new key codes, and if so is it likely to get the new codes, thanks in advance
Username: Lklives
Post Number: 2088
No new keys!..reboot the receiver from switch in BACK...leave off for 2-3 minutes..
IF tha tdoesn't fix it, check your receiver and the disque and antennae settings...since U insinuate U lost ALL channels..
Username: Mdl97
Post Number: 9
any new keys yet?thanks
Username: Knowhow
Post Number: 10
LK you know your stuff!
Here is my problem. I loaded latest bin on classic na, finally go a place to put keys. Scan the channels on 121, got them. Now it says "code is being updated wait..." it takes forever nothing. Am I doing anything wrong? Am I putting keys in the right place? Do I need to put 00 or 01. Can you or anyone help.
Thanks in advance...
Username: Lklives
Post Number: 2095
Not familiar with that newer Fortec classic....I dislike all Fortecs!...no software or support or info at most sites..al7bar.t*k is only place I have seen some support..
"code is being updated wait..." sounds like U have an autoroll bin to me, that will auto enter the latest DN and Bev keys for you....with many receivers, this will take up to an hour and proceed to 1000%..need to put on a DN channel when it updates DN keys, then a Bev channel when it updates Bev keys...U need to know something about the bins U use!
Both keys 00 and 01 are usually put in (4 lines)most receivers...the receiver needs the ACTIVE key which is usually 00 or 01 ,but BOTH keys are ACTIVE since 14 March...Dishnetwork controls this, some channel need key 00 and others need key 01, thats why lately many people are wondering why they do not get PPV , movies and adult channels that are on Key 01..many people do NOT know how to enter BOTH keys and only enter 1 key, instead of BOTH ....and some receivers ONLY allow 1 key to be entered..
Username: Knowhow
Post Number: 13
Thanks LK
Username: Bladam
Post Number: 9
Thanks reboot workded
Username: Lklives
Post Number: 2145
* Apologies for how long it took to get last night's changes all uploaded into the board. Over 350 channels moved so updating the charts took a while. All changes thanks to info provided by (ANON) unless otherwise noted)
* Transponder 3 at 110° (E*6) was moved to transponder 14 (E*8). This affected channels 217/9601, 221, 458, 525-530, 532, 9684, 9685, 9940, 9941
* Transponder 14 at 110° (E*8) was moved to transponder 3 at 110° (E*8?). This affected channels 187, 229, 343, 493, 8300-8303 (Atlanta major networks), 8490-8493 (Chicago major networks)
* Transponder 27 at 110° (E*6) was moved to transponder 6 (E*6). This affected channels 223, 456, 467, 504, 508, 518, 522. 537, 539/864, 841, 842, 9681, 9682, 9686, 9926, 9928, 9934
* Transponder 29 at 110° (E*6) was moved to transponder 8 (E*8). This affected channels 100, 503, 506, 507, 510, 516, 521, 523, 524, 9927, 9929, 9998
* Transponder 31 at 110°(E*6) was moved to transponder 10 (E*8). This affected channels 156/919, 203/893, 216, 218, 219, 485, 538, 988, 999, 9415, 9509. 9611, 9612, 9683, 9900,
* SPRKY (257) a Dish Network Engineering channel which not available to subscribers made its return to 110° on tp 2
* "SPORT" channels 462, 463 and 464 were returned to 110° on tp 2 (E*8) (For those that haven't noticed, transponder 2 at 110° is no longer a spot beam transponder)
* Shreveport, LA locals (7015-7021) and its mirrors on channel 6203 & 6204 for the Tyler, TX market moved from tp 10 spot 8 at 110° (E*8) to tp 27 spot 15 at 110° (E*10)
* The other half of the Ft. Wayne locals (7438-7442) moved from tp 8 at 121° to tp 7 spot 11 at 119° (Yes, 119° not 110°!). The rest of the Ft. Wayne locals moved to 110° last week. The "One Dish Rule" which takes effect in June is a one DISH rule; not a one satellite location rule. To get local channel you must have a Dish 500.
* Sherman/Ada locals (7521 & 7522) moved from tp 10 spot 8 at 110° (E*8) to tp 20 spot 21 at 110° (E*10)
* Harlingen/Browmsville/McAllen local channels moved to tp 29 spot 17 at 110° from (7655-7657, 7659) tp 2 spot 6 at 110°, (7658, 7661-7663) tp 5 spot 10 at 119°
* Pittsburgh local channel (8130-8142) moved from tp 2 and 8 spot 10 at 110° (E*8) to tp 29 spot 9 at 110° (E*10)
* Denver "minor" locals (everything except ABC, CBS, NBC, Fox and KWGN) moved to transponder 12 spot 30 at 110° (E*10) from (8205, 8206 & 8215) tp 4 spot 5 at 110° (E*8), (8207-8212) tp 22 at 148°, (8213 & 8214) tp 6 at 148°. At the same time channels 8807-8814 were removed from tp 16 at 129°
* Orlando local channels 8270-8282 and 8286 moved to tp 31 spot 1 at 110° (E*10) from (8270-8277 & 8286) tp 6 spot 12 at 110° (E*8), (8278-8282) tp 30 at 61.5°. Orlando locals 8283-8285 moved from tp 30 at 61.5° to tp 29 spot 1 at 110° (E*10).
* Fairbanks, AK locals (8292-8299) moved from tp 8 Alaska spot beam at 110° (E*8) to tp 26 spot 46 at 110° (E*10)
* Dallas "big 4" networks, NBC, CBS, Fox and ABC (8400-8403) moved from tp 8 spot 6 at 110° to tp 2 at 110°. (Once again, tp 2 at 110° is now a ConUS beam)
* The rest of the Dallas locals moved to tp 29 spot 21 at 110° (E*10) from (8404-8411) tp 8 spot 6 at 110° (E*8), (8412-8416) tp 8 at 148°. At the same time channels 8412-8416 were removed from tp 16 at 129°.
* Cleveland local channels moved to tp 31 spot 9 at 110° (E*10) from (8510-8516) tp 2 spot 10 at 110°, (8520) tp 30 at 61.5°, (8521) tp 16 at 61.5°. At the same time channels 8520 and 8521 were removed from tp 16 at 129°
* Nashville "minor" locals (8554-8561) moved to tp 27 spot 10 at 110° (E*10) from (8554-8556) tp 6 spot 9 at 110° (E*8), (8557, 8660 & -8561) tp 27 at 61.5°. Channel 8561 is still not available to subscribers.
* Minneapolis local channels (8570-8583) moved from tp 8 spot 7 at 110° (E*8) to tp 4 spot 28 at 110° (E*10)
* Tampa local channels (8690-8703) move to tp 27 spot 1 at 110° (E*10) from (8690-8694) tp 10 spot 12 at 110° (E*8), (8695, 8696 & 8703) tp 2 spot 12 at 110°(E*8), (8697-8702) tp 16 at 61.5°
* Albuquerque local channels (8810-8824) moved to tp 27 spot 31 at 110° (E*10) from tp 6 spot 26 at 110° (E*8)
* Tyler, TX local channels (8880-8883) moved from tp 10 spot 2 at 110° (E*8) to tp 20 spot 21 at 110° (E*10). 8886 KERA which is a mirror of the Dallas PBS moved from tp 8 spot 6 at 110° (E*8) to tp 20 spot 21 at 110° (E*10).
* Fresno, CA local channels (8965-8976) moved to tp 4 spot 38 at 110° (E*10) from (8965-8972) tp 10 spot 2 at 110° (E*8), (8973-8976) tp 21 at 148°. At the same time channels 8973-8976 were removed from tp 21 at 129°
* Colorado Springs locals (9065-9072) moved to tp 4 spot 30 at 110° (E*10) from tp 4 spot 5 at 110° (E*8). Channel 9069 which is a mirror of KWGN Denver and a national superstation remains on tp 15 at 119°.
* Des Moines local channels (9110-9117) moved frpm tp 10 spot 7 at 110° (E*8) to tp 20 spot 24 at 110°
* Buffalo, NY local channel (9125-9133) moved to tp 27 spot 9 at 110° (E*10) from (9125-9126) tp 8 spot 10 and (9127-9129) tp 10 spot 10 at 110° (E*8), (9131-9133) tp 16 at 61.5°
* Omaha, NE local channels (9140-9147) moved to tp 20 spot 24 at 110° (E*10) from (9140-9146) tp 10 spot 7 at 110° (E*8), (9147) tp 27 at 148°. At the same time channel 9147 was removed from tp 15 at 129°
* Channel 9161 KDIN in Cedar Rapids, which is a mirror of the Des Moines PBS channel moved from tp 10 spot 7 to tp 20 spot 24.
* Spokane local channels (9170-9179) moved to tp 18 spot 40 at 110° (E*10) from (9170-9174, 9176, 9177) tp 6 spot 1 at 110° (E*8), (9175, 9178) tp 27 at 148°.
* Sioux City, SD local channels moved to tp 23 spot 32 at 110° (E*10) from (9230-9236) tp 2 spot 7 at 110° (E*8) and (9237, 9239) tp 12 at 148°. At the same time channels 9237 and 9239 were removed from tp 15 at 129°.
* Juneau, AK locals (9178-9184) moved from tp 8 Alaska spot beam at 110°(E*8) to tp 26 spot 46 at 110° (E*10)
* Commercial Sports channels 9800 and 9801 were returned to the line-up on tp 2 at 110°
* ETC3 (a Dish engineering channel) was returned to the line-up hidden from subscribers on channel 9983 tp 2 at 110°
Username: Wnyzfinest
Post Number: 8
I delted all my channels
how do i get channel lists loaded on the Pansat 2500
