Eclipse cd8445 or cd8455
Username: Pvduk
Can someone please point out the differences between the two and what final outcome that has on the SQ output???
The cd8445 is going for $280 brand new on eBay, and the cd8455 for $455 used!!!!
I think the demand for the cd8455 makes it much less value for money!? Please anyone with experience and knowledge on this subject reply! thanks
Username: Pvduk
Bump!
Please you guys, a simple answer will suffice!
Jonathan or Glass!?!?!?!
Username: Delsole
Post Number: 82
cd8445 its new and u will save alot of money
Username: Jeremyc
Germany
Post Number: 843
Yeah unless you plan on running an active front stage go with the 8445. The 8455 is better, but not worth the extra $$ unless you plan on using it to its full potential.
Username: Delsole
Post Number: 119
true true
Username: Ruthless06
Post Number: 74
the 8445 has a 7 band eq.
the 8455 has a 10 band eq
the 8445 has no digital input
the 8455 does
the 8445 does not come with a mic
the 8455 does
the only differences between the two.
Username: Delsole
Post Number: 150
jus get the new cheaper one staight up
Username: Lil_jon
Post Number: 349
get the 55 when its time to upgrade your speakers to high end your gonna wanna go active
you wont be able to do that with the 45
Username: Vinnyqh
Portland, OR
Post Number: 195
als othe 8445 doesn't even have the option for getting a mic. and the 55 has a better DSP inside, hence the 7 band and the 10 band.
Username: Jchin2
is the old model 8061 good?
Username: Extrmndor3
Chicago, Ill Us
Post Number: 554
hel na bro go to best buy and buy the alpine cda-9855 and u will be satisfied i think is better and is available for 300
