Silver Member Username: Sw9152Michigan Post Number: 390 Registered: Feb-06 | what do you think about this amp and what is a good price? i am thinking of buying one. |
Silver Member Username: Sw9152Michigan Post Number: 391 Registered: Feb-06 | and can anyone tell me the difference between the X7.C and the X7.A? the only difference i can see the signal to noise ratio. |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 944 Registered: Jul-05 | are you getting it for a really good price? i know they used to cost like 1400 bucks, my local audio store had a few they were trying to get rid of but noone seemed to want them. |
Silver Member Username: Sw9152Michigan Post Number: 396 Registered: Feb-06 | yeah i think i might be able to get one for under $250. good deal i think, but want to make sure it's not a POS. i am going to sell off my audiobahn a18001dt if i get it and want to make sure i am upgrading. not getting less power or crappy SQ. |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 945 Registered: Jul-05 | well its rockfords highest end amp. what year was it made in and has it been used? |
Silver Member Username: Sw9152Michigan Post Number: 397 Registered: Feb-06 | brand new and not sure on what year it was made. under 250 might be a little low though maybe like 250-300. i thought rf has one higher model. i see them on ebay for around 900. |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 946 Registered: Jul-05 | rockford as the T series but thats not as good as the type RF series. |
Silver Member Username: Sw9152Michigan Post Number: 398 Registered: Feb-06 | oh, the t series seem to be really expensive though. do you know the differnce between the A and C versions? http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-T30001BD-MONO-Amplifier-NEW-Amp_W0QQi temZ9715017251QQcategoryZ64572QQrdZ1QQcmdZViewItem |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 947 Registered: Jul-05 | thats expensive because its 2 times more RMS than the X7. no i dont know they difference. sorry. |
