New member Username: UptwospeedFL USA Post Number: 1 Registered: Apr-06 | I had a separate circuit installed when my house was being built for the home theater components. I think I should have had the whole room on a separate circuit. I have noise coming from my subs. When I turn on the fan there is a loud pop out of the subs. The subs have 3 pins on the power cord. I tried a monster Cable power conditioner level 4 and it did almost nothing to help. What can I do? I think I can hear the microwave when it turns on downstairs. I was thinking about adding a whole house surge protector since I live in Florida but will it do any noise suppression? |
Gold Member Username: Project6Post Number: 7675 Registered: Dec-03 | Bob, welcome to the forum That is a very good question. Try posting it anew here: https://www.ecoustics.com/electronics/forum/home-audio/19.html Jan might be able to help with this. |
New member Username: BoycePost Number: 1 Registered: Apr-06 | Can you try unplug the rca, just plug in the power and turn on the fan, see any noise come up? |
Silver Member Username: MccambleyBREEZY POINT, NY USA Post Number: 147 Registered: Jun-05 | I had a similiar problem with a sub and simply add a gray 3 prong to 2 prong adapter to the sub plug and the hum was greatly reduced. |
New member Username: BoycePost Number: 5 Registered: Apr-06 | I guess you need to find out is ground loop problem, or electric noise from receptacle. |
Gold Member Username: Project6Post Number: 7686 Registered: Dec-03 | The ole ground loop isolator solution, might work |
