Ported Enclosures
Username: Alexv305
Tavernier, FL USA
Post Number: 99
When designing a ported enclosure, how many square inches of space do I use in a port? on ROE it says to use 50 SQ IN, but would it be safe to use more or less?
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2219
depends on the sub and cubic foot of ya enclosure
Username: Alexv305
Tavernier, FL USA
Post Number: 100
Is there some sort of rule to determine now much space you need per cubic inch of total enclosure volume or something?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2750
a decent rule is 10-14sq inches of port per net cuft of box went using slot-ports
ex...3cuft net box---~30sq inches.
this when tuning for daily drivin though (30-38hz)...tuning for SPL it totally different. in some cases, bigger isnt alway better for SPL :-) *hint-hint*
Username: Alexv305
Tavernier, FL USA
Post Number: 103
yea i know that a smaller port tunes the enclosure to a higher freq, i jus needed to know how to design a ported enclosure so it sounds right the first time. lol i dont want to have to rebuild it two or three times.
also what tuning freq should i use on alpine type r 12s and treo tsx 12s. both are going to be used for SQL..
Username: Alexv305
Tavernier, FL USA
Post Number: 104
^^I meant shorter port with same length and width..just a shorter depth
a smaller port in general will cause the whistling effect.
Post Number: 2752
for daily driving...i would recommend ~2-2.25cuft tuned to 32hz w/ ~20-24sq inches of port....per sub.
maybe alil smaller box for the R's...like 1.8-2cuft maybe)
if you do a single chambered box w/ 2 12's...try 4.25cuft w/ 42sq inches of port. (tune to 32hz)
