Bronze Member Username: NorthomahaPost Number: 25 Registered: Mar-06 | I have a 87 range rover with a 200 amp alternator i just ordered from nate at ex amp. I have two bx1500d amps and i need a 2nd battery. It will be inside the passenger compartment so i need one that wont put off any fumes. Any suggestions? are marine batteries safe to put inside? |
Silver Member Username: HighstonePost Number: 147 Registered: Mar-06 | 2 things.. 1st-- are you going to be palying music while ur car is shut off .. if not then u don't need a 2nd battery. but if you are going to play music with ur car shut off then it's fine to get a 2nd battery. 2nd-- i would buy optima batteries(not so cheap)but what's ur budget for the battery? |
Silver Member Username: NypdlapdPost Number: 325 Registered: Feb-06 | go to wal mart and get a marine batt Because it store me and hold the charge better!! AND CHEAPER!!! https://www.ecoustics.com/electronics/forum/car-audio/215124.html CHECK THIS LINK!! |
