Bronze Member Username: KravenbloodOhio Post Number: 47 Registered: Aug-05 | they had one stroker 12 in a ported box hitting 154.9 db.. didnt ask how many watts they where putting through it but it makes me wna tto put my 15 in a ported box instead of sealed lol |
Gold Member Username: Basshead86Slowcala, FL The one that... Post Number: 2884 Registered: Aug-05 | must not have been a TL. |
Bronze Member Username: KravenbloodOhio Post Number: 48 Registered: Aug-05 | next time im there ill ask if it was a term lab they hold comps so i dont see why it wouldnt of been |
Gold Member Username: Basshead86Slowcala, FL The one that... Post Number: 2891 Registered: Aug-05 | that just seems kinda unrealitstic. my shop had a 300zx with 2 Treo SSx's and 2000wRMS on each and the whole back hatch was a ported box right behind the seats and they hit a 152 on the TL. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 852 Registered: Jan-06 | 2 Treo SSX's should be louder than that but again they are only putting 2000 wrms, I have been told they will hold A LOT more than that but the stroker figures are unrealistic indeed. Just to make sure you are talking the same, you are meaning the old school strokers with the web in the middle? If so, there is nooo way, wayy out of date sub, sorry.Polo. |
Gold Member Username: James1115Ct Post Number: 5674 Registered: Dec-04 | was it the old stroker or the new stroker pro? |
Bronze Member Username: JcashPost Number: 14 Registered: Dec-05 | then how the hell is marshall hittin one 148. something witha single re sx and a jbl 1200.1 |
Gold Member Username: James1115Ct Post Number: 5676 Registered: Dec-04 | a nice SPL enclosure tuned to the res freq of his truck, and a very nice install. |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2564 Registered: Sep-04 | 154 is about twice as loud as 148..... thats how. |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 740 Registered: Nov-05 | how do you find the resonant frquency of your truck? mine is very small, but i was thinking of doing something like this.http://www.carstereo.com/installs/photo_gallery_album.cfm?home=yes&photoid=20748 &galleryid=1558 |
Bronze Member Username: KravenbloodOhio Post Number: 49 Registered: Aug-05 | its the 2005 model stroker.. not the stroker pro |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2714 Registered: Mar-04 | ~155 w/ 1 12" stroker....yea, it can be done hell of a box, lots of power, hatchback....nuff said. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 853 Registered: Jan-06 | Stroker PRO 15 Specifications Diameter: 15" No. of Voice Coils: 2 Power Handling: 2500 Wrms (cont. unclipped power (1250 Wrms per voice coil) per EIA RS-426B) Frequency Response: 36~200 Hz Voice Coil Diameter: 4.0" Total Weight: 68.3 lbs, (15.4 kg) Mounting Diameter: 161⁄4" (41.27 cm) Through Hole 14" (35.56cm) Mounting Depth: 9" (20.32 cm) Stroker PRO 15 Thiele-Small Parameters 15 Free-Air Resonance: fs 26.4 Hz Total Q: Qts 0.72 Mechanical Q: Qms 7.8 Electrical Q: Qes 0.79 Comp.Vol.: Vas 3.6 ft3 Max. Excursion: Xmax 40 mm Voice Coil DC Resistance: Revc 2 x 1.80 U Vol. Displace.: 285 in3 (0.165 ft3) Nominal Impedance: 2 x 2 U Sensitivity: 86.3dB |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 854 Registered: Jan-06 | They recommend a 1.2cf ported and tuned @49hz for the 12 and 2.4 for the 15 tuned to the same. It is an SPL sub and I have seen a lot better specs out of other more cheaper costing subs. JMHO...Polo. |
