Silver Member Username: LewassBoomfield Hills, MI USA Post Number: 641 Registered: Jan-06 | I am running off the rear channel, what is the preout voltage on it? |
Gold Member Username: IlluminatorUSA Post Number: 2893 Registered: Apr-05 | 2 Volts. http://www.cardomain.com/item/PIODEHP4600MP It also states 2V on the Pioneer website, but ecoustics.com doesn't let me link it properly. |
Silver Member Username: LewassBoomfield Hills, MI USA Post Number: 642 Registered: Jan-06 | Ok, so if I have my amp gain set at just under 1 volt, what will happen to my bass if I set it at 2 volt? It's a Kenwood eXcelon X812D |
Gold Member Username: IlluminatorUSA Post Number: 2899 Registered: Apr-05 | It will turn the sensitivity on the amp down resulting in less bass. However, there will be less chance of distortion when you turn the volume up loudly. |
Silver Member Username: LewassBoomfield Hills, MI USA Post Number: 643 Registered: Jan-06 | Good call, that's what I thought too, just wanted to check, and sure enough when I changed it to 2v, it was about half as loud as before. I am going to keep it at 1v, how careful should I be with the volume control? I don't go higher than 47 out of 64. |
Silver Member Username: LewassBoomfield Hills, MI USA Post Number: 644 Registered: Jan-06 | Thanks |
Silver Member Username: KklaggePost Number: 226 Registered: Dec-04 | You're throwing a lot of distortion in there...buy a more powerful amp and set the gains the right way. |
