Dimming Headlights
Username: 20la20
Franklin, TN U.S.
Post Number: 12
I am running 3 10" Kicker CompVRs so I was gonna put in a cap and the guy at the audio place told me to get a YellowTop battery which would stop the dimming, but I got one installed and it helped but it didn't completely stop it. My question is whether I should get a cap or put my old battery in and mount the yellowtop in the trunk so i would be running 2 batteries? Which one would be better?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1840
neither will help if you don't have a HO alt thats large enough.
a second battery is only good if you listen while the car is off.
caps only stabalize voltage, filter out ripple and slightly increase amp response.
Username: Dustin3
Tigard, Or U.S.
Post Number: 877
people really need to read a couple threads down or up to find out that A CAPACITOR WONT FIX YOUR PROBLEM, HO ALT
