Sub woofer stop playing
Username: Gab2k
Qc Canada
hi
i have a new sound system for my car
1 sub alpine 12" type S
http://www.alpine-usa.com/en/products/product.php?model=SWS-1242D
1 amp alpine mrp-f450
http://www.alpine-usa.com/en/products/product.php?model=MRP-F450
After installation i have sound and bass but i always have noise in sub.The sub always play like to be burned. and after 2 days of use i lost bass. i have sound at the output of amp but sub look like to be burned.
My amplifier is a 4ohms
i have plug the sub in 2ohms mode but its a 4ohms + 4 ohms.
i can plug my sub in 2 or 8ohms mode.
i wanna know if bad ohms ajustement can burn the sub or its was the sub had a malfunction
Thanks
Gab
Username: Young_james
Post Number: 1194
first of all, how high did you have your gain set?
Username: B101
Queen City, NC USA
Post Number: 2360
"i wanna know if bad ohms ajustement can burn the sub or its was the sub had a malfunction "
Yes... if the subs are wired incorrectly, or at too low a ohm load like 2ohms; Then placed on a amp thats only stable to 4ohms... It will load the amplifier down, and make the amp produce a clipped signal to the subs.. which in turns burns the voice coils up in the subs...
The amp and sub work together...
Think of a amp being a circuit that is OPENED.. (nothing connected)
Adding a sub will CLOSE the circuit (connected)... The sub needs to be the correct resistance that the circuit of the amp is designed for...
Username: Gab2k
Qc Canada
thanks a lot guys
i will have another sub this weekend :D
if i set the jumpers in the sub at 8 Ohm did this can burn the sub because i have 2 setting 2 Ohm or 8 Ohm.
Gab
