Would my subs hit harder if I bridged my amp?
Username: Goatin
U.S.A
Post Number: 771
I have 2 4ohm R's wired to 2ohm on 2 CH.
My amp is supposed to be 600 X 2 @ 2ohms
If it is bridged it is supposed to be I think 1200-1600 RMS Cant remember exactly @ 4ohms.
So would it be better to run them bridged or does it make a difference??
Username: Matt12490
Benicia, California USA
Post Number: 712
so i take it that your R's are single 4 ohms each?? if thats the case, you can not bridge them. if they were both dual 4 ohm voice coils each, then you could wire the 2 in series / parallel and it would create a final load of 4 ohms and then it would be possible
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 596
Well currently each speaker is getting 600rms...so if it puts out 1200 rms when bridged...each speaker is still getting 600rms...
is your amp stable at 1ohm?...if so try that...if not find out the eaxt number of RMS when bridged....then divide by 2...
Username: Goatin
U.S.A
Post Number: 775
It is only 2ohm stable unless bridged then its 4ohm.
My R's Are DVC and I can wire 2 4ohm subs to 4ohms.
I was just wondering if my amp would be more efficent bridged to 1 CH.
Username: Goatin
U.S.A
Post Number: 776
Username: Goatin
U.S.A
Post Number: 777
Username: Goatin
U.S.A
Post Number: 778
WHY WONT THIS BUMP!!
Username: Matt12490
Post Number: 713
who knows... where does everyone get those gifs of the faces moving?? im looking for that head bopping one..
Username: Matt12490
Post Number: 714
Username: Matt12490
Post Number: 715
ooh if they are dual VC then yes, i would suggest bridging the amp. im not sure if this is correct or not.. but since its producing 600 into 2 channels then its in stereo which means it could be sending musical frequencys to the subs also?? correct me if im wrong, because when i hooked up my sub to my home reciever it was in stereo and i could hear voices coming from the sub... so if you bridge it, it would be at 1 channel which is mono which is what you want for your subs..
Username: Rovin
Trinidad & T...
Post Number: 7389
y dont u post ur amp's model no ....
Username: Goatin
U.S.A
Post Number: 780
Its a Ultra Linear 2800 I didnt think anyone heard of one you cant find it anywhere on the web.
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 428
yea i would Bridge em.... Wire em into parallel... making 2 ohms each sub... than series them togeather for a total of 4 ohms...
or
Wire em into series... making 8 ohms each sub... than parallel them togeathercfor a total of 4 ohms...
