Is a KX2500.1 amp to much power for 2 12" cvx?
Username: Don_beeski
Bourbonnais, IL Kankakee
Post Number: 32
I was told a kx2500.1 amp is to much power for my 2 12" cvx's. I have both of these items coming to me. If it is to much what should I do? Any suggestions?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1635
what are your subs vc config?
Post Number: 33
duel voice coil 4 ohm.
Username: Ctmike
Ct.
Post Number: 305
the amp is 1200wrms at 4, and 2500wrms at 2ohms right? if so wire them at 4ohm, you'll be underpowering them each by like 150w, but i know kicker underrates there amps, so depending what you're amps' birth sheet says, you'll probably be giving them about exactly the subs rms.
Username: Terry6405
Sullivan, IN US
Post Number: 682
^^^^yea, it should sound a little cleaner than 1ohm too, but thats just what ive heard, i dont know if you can tell the difference
Post Number: 34
I haven't put everything together yet. What I use just my regulat alt, will it damage anything?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 430
maybe your lights will dim if your alt can't put the amperes it demands, maybe you should buy one but first install it and then you figure it out
Username: Gravestream
Ok, You want some real advice, its never wise to crank the gain on your amp all the way up anyways, its bad on the amp, which means you'll never get everything out of it to start. You can always overshoot with power, just turn the gain down, this way, if you pop subs, you can just get new ones to fit the amp. You choose good stuff, don't worry about trying to match power because in my expierence it never happens
Username: Juliob
Post Number: 458
"You choose good stuff, don't worry about trying to match power because in my expierence it never happens"
wrong, you should buy good stuffs and match power
Username: Dustin3
Tigard, Or U.S.
Post Number: 866
yup. i agree
Username: James1115
Ct
Post Number: 5668
man where is glass to rip this guy a new a$$hole when you need him? I agree aswell^
