MTX amps?.........
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 590
How are they? Are they over rated? under reated?
just saw in the paper that somone is selling a MTX 8100D (1500rms) for $350...should I try to pick it up at like $250-$300 or somthing?
I would just plan to build a little system and sell it to make some extra bones
thanks
Post Number: 591
(canadian prices)
Username: Nveselinovic16v
Post Number: 51
Thats a great amp. The same as 1501d. puts easilly over 1000w at 12.5w. Underrated by about 10%. I used to have 4x1501d radted at 1kw at 12.5v, did 1.1kw.
Never overheat, i ran them 1 ohm always.
Username: Sw9152
Michigan
Post Number: 339
250-300 canadian for a mtx 8100d is a good deal, i would buy it. if you got some decent subs off ebay or out of the paper and put them in a box you could make a couple hundred bucks off the deal if you find the right person.
Username: Young_james
Post Number: 1177
I have a smaller mtx amp that produces 488wrms @ 2ohms that I have hooked up to a type r and it sounds excellent. Never get's hot either. Honestly, I really like that amp. Mine was rated at 400wrms @ 2ohms, so I'm getting 22% more power than rated :-)
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1604
um i got 12.2% more power when i figured it up LOL, but ya mtx amps are good, good budget amps, my friend had a 1501d and had it running at 1.4ohm and it never overheated or anything, i'd rather have kicker orion or re before mtx but its all personal preference.
Post Number: 592
Sweet I'll look into it more than!
Username: Redliner
Wilmington, Ma
Post Number: 1341
i have 2 mtx amps a a thunder 942 and a 801d they have never giving me any trouble at all and they are rated right around were there suppose to i think the 942 is overrated though cause its suppose to put out 942 but only puts out 900
Post Number: 1183
^^wow, that's weird. Never heard of that happening to mtx amps before
Post Number: 53
the 942 is supposed to make at least 900watts rms and it does thAT
Post Number: 594
So this amp would do 1000-1500rms then?
Username: Redliner
Wilmington, Ma
Post Number: 1350
"the 942 is supposed to make at least 900watts rms and it does thAT"
actually i just found the birth sheet and it was tested at 877
Post Number: 595
OK so the 1500rms will do at least 1000 then....
Username: Redliner
Wilmington, Ma
Post Number: 1351
it will do right around 1500 ost likely above there amps are usually underrated mine is just weird i guess
Username: Bassheadjosh
Utica, MI US
Post Number: 38
Would it be ok to run the 1501d or the 81000d at one ohm for a daily driver? I have 3 12" dual 6 ohm subs and I love mtx amps. I have a 564 already and those mono amps would match that perfectly...what you guys think?
