Username: Re_baby Okc,
Ok
Usa
Post Number: 35 Registered: Mar-06
Monday, April 17, 2006 - 14:25 GMT which would be better titanium or alumimum and whats the difference
Ok
Usa
Post Number: 36 Registered: Mar-06
Monday, April 17, 2006 - 15:10 GMT someone hello
Username: Redliner Wilmington,
Ma
Post Number: 1342 Registered: Jun-05
Monday, April 17, 2006 - 15:42 GMT titanium is better
Username: Rovin Trinidad & T...
Post Number: 7343 Registered: Jul-05
Monday, April 17, 2006 - 16:16 GMT go check it on eclipse website big difference in wattage , price etc & how loud u want it ...
Username: Gkaste Post Number: 17 Registered: Apr-06
Monday, April 17, 2006 - 16:19 GMT goldium is best
Username: Tdeaton1021 Near Tampa,
Florida
Post Number: 2481 Registered: Sep-04
Monday, April 17, 2006 - 20:45 GMT any1 checked out the sw8000 aluminums? they look good. i hope their subs arent going to go downhill like the Hus so ive heard.... and a Ti will be louder but the ALs should sound better
Username: Sw9152 Michigan
Post Number: 351 Registered: Feb-06
Monday, April 17, 2006 - 20:49 GMT titaniums are 1500wrms not 750 like eclipse-web.com says. they rated them per vc.
Username: Lbeckner Tulsa,
Ok
Usa
Post Number: 981 Registered: Oct-04
Monday, April 17, 2006 - 21:30 GMT are you absolutely sure about the ratings? Cause I'm running 4 12"'s off of a Kicker 2500. Ooops. Are you saying that I could double the power?
Post Number: 353 Registered: Feb-06
Monday, April 17, 2006 - 21:48 GMT yes, i am absolutely sure that the ti series is 1500wrms.
Ok
Usa
Post Number: 982 Registered: Oct-04
Monday, April 17, 2006 - 22:34 GMT what should I do then to double the power? I dont think my amp is strappable. I sure would hate to use only half of the speaker. They sure are awesome subs though. I only have two 12's running right now and they hit almost as hard as my two 15" L7's did and sound WAY better doing it. I'm very impressed.
Username: B101 Queen City,
NC
Post Number: 2332 Registered: Sep-05
Monday, April 17, 2006 - 22:38 GMT "which would be better titanium or alumimum and whats the difference" what sounds like its better to you>?? just say them out loud... LOL aluminium is what u put in the oven...
Username: Pelona Perris,
California
Post Number: 1335 Registered: Dec-05
Monday, April 17, 2006 - 23:36 GMT u should never put any metal in the microwave. for those who didnt know. now u know
Post Number: 356 Registered: Feb-06
Tuesday, April 18, 2006 - 01:11 GMT yup, get 1500wrms to each sub asap. insane excursion
California
Post Number: 1336 Registered: Dec-05
Tuesday, April 18, 2006 - 02:10 GMT and dont put it in the microwave
Ok
Usa
Post Number: 983 Registered: Oct-04
Tuesday, April 18, 2006 - 02:11 GMT I have sealed fiberglass boxes now. Should I try to make them ported? Can I just add a port?
Ok
Usa
Post Number: 37 Registered: Mar-06
Tuesday, April 18, 2006 - 14:21 GMT my friend had a eclipse 15'' i dont no if it was a ti or al but it get loud i think its one of the loudest subs out there but i need some help i want to get some but i dont no if i sould get 2 15'' or 1 18'' and if i get a 18'' do i need a new alternator
Ok
Usa
Post Number: 38 Registered: Mar-06
Tuesday, April 18, 2006 - 15:12 GMT anyone
Username: Swisher Marianna,
FL
Post Number: 40 Registered: Apr-06
Tuesday, April 18, 2006 - 17:32 GMT i seen a 18 ti pro hit 161 but it had 8 amps and a box that took up from the front seats back and it was a tanker with 1 1/2 inch glass
Ok
Usa
Post Number: 39 Registered: Mar-06
Wednesday, April 19, 2006 - 15:10 GMT what do u think the best amps(two amps) to run two 15'' eclipse ti one amp to each sub
Ok
Usa
Post Number: 41 Registered: Mar-06
Wednesday, April 19, 2006 - 15:35 GMT asp
Username: Shman Michigan
United States
Post Number: 30 Registered: Mar-06
Wednesday, April 19, 2006 - 20:04 GMT rf X7 to each
Post Number: 375 Registered: Feb-06
Thursday, April 20, 2006 - 03:00 GMT I SECOND THAT ^^^ ARCHIE. A ROCKFORD FOSGATE X7 WOULD BE PERFECT TO EACH. EITHER THAT OR RF 1500BD OR MTX 1501D WOULD WORK TOO. THE X7 IDEAL THOUGH.
United States
Post Number: 32 Registered: Mar-06
Thursday, April 20, 2006 - 03:12 GMT somehow i figured you'd agree sw......lol
United States
Post Number: 33 Registered: Mar-06
Thursday, April 20, 2006 - 03:14 GMT I CANT WAIT FOR MY ARSENAL!!!!!!!!!
