New member Username: Burtonsnol3ordePost Number: 2 Registered: Apr-06 | I've got two 15" Memphis Power Bass subs I used to use in my car. Each had a 2.5 cuft sealed box. In my car the subs sounded very "dry" if they were heard straight through the trunk, but in the car they sounded alright. I wondered if anyone could help design a Isobaric/Ported design tuned to around 20Hz. I wanted to try Isobaric because the subs have a very high Vas and i want to keep the box size as small as possible. Sub Specs are: Fs: 25Hz Vas: 10.2 cuft Qts: 0.6 Xmax: .22" |
Gold Member Username: RovinTrinidad & T... Post Number: 7358 Registered: Jul-05 | um - u r going about it all wrong man , i never heard of anybody tuning a box 20hz ! - thats the lowest a human ear can hear man. u usually tune a box just above the Fs they give u on the spec sheet . If u want more spl u could tune high as 35-40 hz even higher depending on the sub . If u want SQ u tune lower like 28-34hz roughly . Isobaric boxes r VERY complicated 2 calculate & build , stick with basic pipe or slot ported if u have experience or have the space 4 slot ported ... |
New member Username: Burtonsnol3ordePost Number: 5 Registered: Apr-06 | Well I want as much SQ as possible, I don't really care how loud it is. I used to just want LOUD but my music preference has changed. My concern is that the speakers sounded so "dry" and i thought if the sound was chambered and ported it would lessen that. Any other advice? |
New member Username: Burtonsnol3ordePost Number: 6 Registered: Apr-06 | Here is a picture of what i was thinking http://www.the12volt.com/images2/isobandpass.gif |
Gold Member Username: RzarectorCoquitlam, Bc Canada Post Number: 1067 Registered: Dec-04 | isobaric is sorta waste of a sub.. you will barely gain any spl with a second, and if your looking for sq that is NOT the box to build.. also tuning 20 hz is a bit of a waste as well its usually not a good idea to tune below a drivers fs , tuning to around 28 would be just as well.. another thing the subwoofers your using have a high qts at 0.6, that means there more inclined to sealed enclosures. so moving to any sort of ported enclosure you will lose SQ |
Gold Member Username: RovinTrinidad & T... Post Number: 7362 Registered: Jul-05 | imo - those few iso boxes i heard have terrible SQ & a annoying boomy bass with what u said above - u should then def go SEALED really super easy 2 build a sealed box http://www.the12volt.com/caraudio/boxcalcs.asp ... |
New member Username: Burtonsnol3ordePost Number: 8 Registered: Apr-06 | I understand... but they are in 2.5 cu ft sealed boxes right now and the sound is really "dry" i dont know how else to describe it... and i want to eliminate that... I also wanted a smaller box, which is what an isobaric build would do. Thoughts? |
Gold Member Username: B101Queen City, NC USA Post Number: 2359 Registered: Sep-05 | ISO boxes need to be tuned high... why are the subs sounding Dry? what amp is powering them? and are the xovers and gain set properly?? if you want SQ then u want SEALED like Rovin stated above... I think u have alot to learn man, start here: http://www.diysubwoofers.org/ |
