I have the following: Infinity ref 5761a 6-ch amp Infinity ref 6010cs wired to (ch 1/2) Infinity ref 6012si wired to (ch 3/4) Infinity kappa 100.3 dvc sub 4 ohm/coil bridged to (ch5/6) Sub is wired parallel.
Question. Is the sub wiring ok on both sub & amp. i have received comments from other forums namely: 1. wire each sub vcoil separately to ch 5/6 2. wire sub vcoil in series then bridged to amp (which i tried but got a lesser "bump" from my sub) Need help on this badly. Getting another sub or amp is out of the question. Need to work with what i have now. Thanks. Ronald
