I think I killed my Ariza 700 receiver...
Username: Ajaychopra
by loading Ariza 750 file. I have now restored to factory settings but cannot load bin 272 or 268. I get an error message 'Flash Upodate failed'
Please suggest what to do...
Username: Wakenbake
Post Number: 41
post where you got file
Username: Wakenbake
Post Number: 42
toooo much bs here
Sorry - didnt understand what you meant? I received 2 files from my provider and he is unreachable now.
Username: Lklives
Post Number: 1934
flash failed...wrong or defective cable or SERIAL port!
Username: Wakenbake
Post Number: 43
find new provider
future has files
I am using the same serial port and cable and actually even tried with another cable. Same problem.
What else could it be?>
What is 'future' in 'future has files'
Username: Wakenbake
Post Number: 45
its called testing
use what works
Username: Wakenbake
Post Number: 46
too funny
if it worked before it will work again
Username: Lklives
Post Number: 1937
bin doesn't matter if "flash failed"...if the cable or serial port are the problems what difference will the bin make...a little common sense..if U can't start the car, who cares what grade gas to put in...
Username: Fruitcakes
Post Number: 81
This is the fcuking gayest avatar I have ever seen...anyone recongnise it...ROTF
Username: Wakenbake
Post Number: 60
get a life AZZhole
Username: Wakenbake
Post Number: 61
this is the LAST place to info
use search better
Username: Lklives
Post Number: 1945
FRuitcake ...again U disrespect my country the US, US military and the US soldiers!....U should be treated as a traitor and terrorist!...U are the same as them!...and so is Ecoustics, for allowing U here for years!
Folks,
thanks for generous responses. Here is what I think has happened, let me know if you have encountered this?
I did install 272 BUT the biggest mistake was to install it while it was still connected to the TV and the cable...Folks is it BAD? Well, from then on I have not been able to install another BIN!!! I have tried different computers and different cables, same story.
Here is what I think - I may have done something to the receivers serial port... Anyone???
Username: Forbidden
go here fella
[link removed]
Username: Lklives
Post Number: 1950
Ecoustics is being investigated for child por*nography due to the posts by FRUITCAKE and all his aliases...stay away!
