What size fuse?
Username: Killer44
Ontario Canada
Post Number: 489
i blew a fuse, my power wire is 4 awg and only powering a alpin flex 2 ( 60X1 channel, channel 2 is not working) going to 2 infinty reference 6.25's...gunna be adding kicker cvr 10's and A8002T soon...Optima Yellow top, H/o alt(about 150 amps)...the audio store around here only has 80 amp fuses rite now...is that enough? thanx in advance
Username: Killer44
Ontario Canada
Post Number: 490
ne one...?
Username: Adddisorder
Post Number: 130
iv got an 80 or a 120 on my 4g power if all you can find right now is 80 then try it.
what size did you have in there befor?
make sure that wire isnt getting grounded anywhere or any other positive terminals, because one channel on your amp isnt working that may have soemthing to do with it because that amp shouldnt draw tons of current
Username: Killer44
Ontario Canada
Post Number: 491
no what happend wa when i was making my amp rack i diconnected the power and ground from the amp and they accidently touched....ya i jsut ended up gettin a 80 amp...thanx matt
