Hi everyone, I'm new to this and have looked a little through this site. All I get for satellite choices are echo 7/KU and echo 6.8/KU. This seems to be Kentucky? How can I find the echostar 7 and echostar 6,8? My Pansat 2700 will not even show them as options to recieve. Do I need a different box?
Thank you for that info. Why do I get so many channels that are repeated, and get only 1 HBO, and only a bunch of spanish channels. I don't even see channels like cnn, except in spanish? Not even the local channels. At least I get a couple of the adult channels. I installed the last updated codes, what else do I need to do to get all the channels.
Delete all of your channels (in "channel edit") and then do a blind scan for both satellites. Also, grab the latest bin for the 2700. After the scan you can use a program call "channel master" to edit the list.
Another option is to download, off the Net, a channel list. But, sometimes the list is edited so that some channels are deleted. These list should not have the duplicate channels. You can then download the list to your receiver.
LK I have a card that is white mainlly and says express vu and dish network on the card.the first 3 digets in the cam are S 04. do you have any idea what card this is?
