Please help!!!!! fuses blowing
Username: Ldskin
Fort Sask., HUH Canada
Post Number: 9
I just spent all day wiring up subs in my girlfriends truck (something i have done so many times in the past) and the fuses on the amp blow as soon as i turn up the volume. I have never had this happen to me before, whats wrong???????
Username: Young_james
Post Number: 1170
Sounds like your clipping your amp majorly. How high do you have the gain set? When you turn it up the fuse pops? Try adjusting the gain/bass boost and volume to see if it happens
Username: Jmloughrey
Farmington, CT
Post Number: 1486
if your playing the system and the fuses blow chances are your clipping your amp severly and your gain is most likely much too high, i really wouldn't doubt its all the way as thats a quite common misconception.
If its popping before you even get the radio turned on then you could possibly have a bad ground, short somewhere...
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 317
whats that mean if your clipping the amp?
Farmington, CT
Post Number: 1490
www.bcae1.com
go to option on the right hand side
that'll explain what you need to do
