I need help/advice on choosing an amp to power 3 infinity 1230w's. They're each 300 watt rms so 900 total; which means i'll need at least a 1000 watt mono amp but anything from 1000- 1500 will be good so i can have some headroom with the gains set low. My budget is running kind of low so i'll be spending up to $280 maybe $300. Thanks in advance
PS: Some of the amps I have in mind are the hifonics brutus bx1205, mb quart raa1000, and the MA AUDIO HK2000D... If you need links just ask.
Id go with the mb quart,i have one powering my 12w6v2 and it sounds great. It will problly put out more than 1000 watts. I dont know why they stopped makin em they are great amps. But are u sure that those three subs can be wired to get a 1 ohm load?
