Bronze Member Username: TippindownPost Number: 31 Registered: Mar-06 | what are the best spl 12's for around or under 200? |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1478 Registered: Jul-04 | ...you wont get all that much for $200.... |
Silver Member Username: Sw9152Michigan Post Number: 300 Registered: Feb-06 | kicker 12 L7 dual 4 and audiobahn a8000t would prolly be cheapest setup. |
Bronze Member Username: TippindownPost Number: 32 Registered: Mar-06 | well i was gonna go all out but i think im gonna start small with 2 12's and get some new rims then when i save up enough money get me 2 15's so what would be the best 12's for about 150-200 and a good amp? |
Silver Member Username: Loc_outSanta Ana, Ca Post Number: 366 Registered: Feb-05 | Do you already have an amp? thats 150-200 on just the sub right? |
Bronze Member Username: TippindownPost Number: 33 Registered: Mar-06 | yea just 150-200 on the sub and no i dont have an amp, and im gonna get 2 of them, so what u think are the best spl 12's for aboput 150? |
Bronze Member Username: TippindownPost Number: 34 Registered: Mar-06 | yea just 150-200 on the sub and no i dont have an amp, and im gonna get 2 of them, so what u think are the best spl 12's for aboput 150? |
Silver Member Username: CtmikeCt. Post Number: 202 Registered: Feb-06 | this ones $189 and should be good http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14810 |
Bronze Member Username: TippindownPost Number: 35 Registered: Mar-06 | anyone heard alpine type r's i think im leaning toward them are they sq or spl? |
Bronze Member Username: TippindownPost Number: 36 Registered: Mar-06 | anyone heard alpine type r's i think im leaning toward them are they sq or spl? |
Silver Member Username: CtmikeCt. Post Number: 203 Registered: Feb-06 | i got a pair of type r's and they get loud but i wouldn't consider them spl. you wont be disappointed with them if you get them, but if you want straight spl i wouldn't get them, there more sql than spl. |
Bronze Member Username: TippindownPost Number: 37 Registered: Mar-06 | well thats kinda what i was lloking for anyway, what would be a good amp(s) choice for them? |
Silver Member Username: CtmikeCt. Post Number: 210 Registered: Feb-06 | kicker 1200.1 jbl 1200 ed 1200 nine.1 what's your budget? i have a kicker 1200.1 on mine and its' perfect. just get an amp that'll put 550-650wrms to each. |
Bronze Member Username: TippindownPost Number: 38 Registered: Mar-06 | not postive on the budget cuz i was thing of spending like 1200 and getting the havoc and a big amp butcut it down so i could get some rims but prolly like 300 somewhere around there |
Silver Member Username: CtmikeCt. Post Number: 213 Registered: Feb-06 | unless you get one online from unauthorized dealer, if thats something you dont mind, i would lean towards the nine.1. but you can shop around and might find something else. |
Bronze Member Username: TippindownPost Number: 39 Registered: Mar-06 | im looking on ebay and whats the difference between the 1222d and the 1242d i know like the ohms but i dont really understand what the diffrence is if im going to get the kicker what would be better the 1222d or the 1242d? |
Silver Member Username: CtmikeCt. Post Number: 214 Registered: Feb-06 | if you get the kicker 1200.1 get the 1242d. you can't wire the 1222d to 1ohm load. |
Bronze Member Username: TippindownPost Number: 41 Registered: Mar-06 | well i posted before u said something about the nine.1 so ill prolly be going with that so what one would be better? |
Silver Member Username: CtmikeCt. Post Number: 215 Registered: Feb-06 | i would say kicker. good brand and build and underrated. the birth sheet in mine said around 1430rms i think. but i've read good reviews about the nine.1 and have asked about it myself and i'm thinking of them for next set up. but if your budget fits it i'd say the kicker. |
Silver Member Username: Terry6405Sullivan, IN US Post Number: 661 Registered: Sep-05 | i got my nine.1 for 300 shipped with 3 year warranty from a fuy on CA.com |
Bronze Member Username: TippindownPost Number: 42 Registered: Mar-06 | well which type r( 1222d or the 1242d ) if i get the nine.1? |
Silver Member Username: CtmikeCt. Post Number: 219 Registered: Feb-06 | 1242d |
Bronze Member Username: TippindownPost Number: 43 Registered: Mar-06 | aight cool thanks man anyone know best website that sells type r's for cheap with good warranty? |
Silver Member Username: CtmikeCt. Post Number: 224 Registered: Feb-06 | http://carstereoexpo.com/swal12tysesu1.html they give one year warranty thru them. price aint bad neither. |
