Is it possible to wire dual 4ohm voice coils to run at 2ohms?
Username: Bumpthat
I am planning on getting 2 Alpine type R's. They each have dual 4ohm voice coils. I also might get a Kenwood 1800w mono amp. Is there ANY way possible to run it at a 2ohm load. I have been told its not. If not, can it be run at 1ohm and is that a good idea or not?
Alpine Type R 10" sub
http://www.crutchfield.com/S-Su5lMVvNfpo/cgi-bin/ProdView.asp?i=500SWR1042
http://www.justkenwood.co.uk/stock01/kac9152d.asp
Username: Ctmike
Ct.
Post Number: 200
i think the only way to run it at 2ohms is if you have one amp to one sub. if you're running one amp to both subs then you can't, you can run it at 1 or 4ohm.
it's always best to try and run it at 4ohm load, but running it at a lower one will get more power from your amp.
i had/have a pair os 12" r's running at a 1ohm load off a kicker 1200.1 and it sounded real good but i don't know about the kenwood mono amps. i heard there bigger amps get really hot and have a tendacy to shut off.
Username: Sw9152
Michigan
Post Number: 296
the amp is advertised as 1 0hm stable so i would say it is okay to wire the subs for a 1 ohm load.
Username: Inafia
Cleveland, Ohio USA
Post Number: 16
dual 4's in a 2 ohm load...wire them in series and bridge them correct?
Username: Inafia
Cleveland, Ohio USA
Post Number: 17
wire them in series and bridge them into the amp, im pretty sure?
Username: Sw9152
Michigan
Post Number: 297
NO NO NO!!! inafia it is IMPOSSIBLE to wire 2 dual 4 ohm subs into a 2 ohm load!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
Username: Lewass
Boomfield Hills, MI USA
Post Number: 618
A 2 channel amp that is 2 ohm stable.... Wire all in parallel and put one sub to each channel...
Or two 1 channel amps.
Username: Matt12490
Benicia, California USA
Post Number: 649
if he had a 2 channel amp then it would be better to wire them into a 4 ohm load and then bridge the amp. shane, if you want a 2 ohm load, im pretty sure they make the type R's in dual 2ohm or single 4.
Username: Bumpthat
^^^ cant find it, if they do
someone mentioned that the kenwood amps shut off?
and since it sounds like i will be getting a different amp, what would you guys recommend?
either a 2way amp or two single amps that can power the speakers
should i repost this in the amp forum or is it basically the same people there?
