ive been hearing that audiobahn subs are crappy and there amps are alright,but have anyone had any experience with there mids&tweets,6X9,s and pre-amps.i know there not the best,but are they alright.i want to know about there higher end stuff. not entry level
i have an 650x4 amp and a budget of about $600 for all the high's 3 or 4 way 6x9's,6 1/2 components and some 3 way 6 inch full range speakers oh and some 3 1/2 dash speakers too
Audiobahn subs have performed well for me in the past. Are they the best subs out.... No! But they are far from crappy. It all depends on your purpose. If you want loud they do that and they do it well. Mine lasted for a year with no problems until I moved to a 12w7. As I always suggest go take a listen and judge for yourself.
my entire setup is audiobahn i have no problem out of any of them they give the loudness and sound quailty that i am asking for with them...i have friends with infinity and jbl and others and the audiobahn have better sound than them. but hey its what ever you want its your money,
