Battery is dieing
Username: Ecko_man2k2
Hi, I have two amps running in my car...
- Ones a 444watt Sony Xplod amp and the other is
- 1200 Sony xplod amp
I have the 444 running my 6x9s and
1200 Running my 2 12" subs.
After playing around for a while...My car wouldnt start and I had to jump it...Whats an inexpensive way to fix this?
Username: Killswitchjd
Post Number: 14
get a yellow or red top battery, or take the amps out. Although sony is not extremely good, it is still power hungry... Maybe HO alt as well
Check out my pics in the bragging area (only accessible through the pulldown top menu under forum, then car audio...
Username: Tjmutlow
Post Number: 1898
keep the car on if it is off, you would be able to run a system for extended periods of time with car off anyway..
