Need an amp
Username: Genocyde21
Hey guys. I just bought 2 pioneer TS-W306R. They are rated 400wrsm 4ohm each. I need an amp, preferably a pioneer (i get a discount) that would power these two. You guys have one in mind?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 382
well, pioneer amps are not good at all, personally it seems that you're in a budget so go with hifonics 1205D if they're dual 4 ohm subs
Username: Dustin3
Tigard, Or U.S.
Post Number: 743
since they are rated at 400 rms you dont want to give the pioneers too much power like the hifonics one would. i would get the audiobahn a8002t. gives each sub 400 watts, and they run you around $ 115 shipped on ebay.
nice. Right on the spot. No i'm not on a tight budget, just i get a discount, and second off i always had pioneer and never had any probs... Thx for answering :-)
Username: Tjmutlow
Post Number: 1891
if those are single 4ohm subs, you do not want a 2 channel amp, like the metioned Audiobahn, you need a 2ohm stable amp, you can get the Audiobahn 8000t which will work for those subs for cheap,i would not run more then a 400-600w good mono on them, like a kicker 400.1 or alpine mrd 650. not much more the rms power to them for the pair would be just fine...
Username: Rovin
Trinidad & T...
Post Number: 7215
which model do u have ?
the 306C is the SVC model
306DVC is the DVC model .......
i dont know lol.... I bought them from bestbuy... here the link
http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0926INGFS10 060201&catid=20119
if there was a difference, the seller didn't tell me. The F*cker, he lives 3 doors away from me. I'm going to wake his *ss up in the middle of the night if he didn't give me something good :P
Username: Rovin
Trinidad & T...
Post Number: 7222
go look on a sub & tell me if it has 1 or 2 pairs of terminals on it ........
just checked. Dual voice coil.
Username: Rovin
Trinidad & T...
Post Number: 7226
i had ur same subs
buy this amp - i have 1
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
thats one nice amp :-) Thx for the imput
