Bronze Member Username: DarrenmunskPost Number: 14 Registered: Apr-06 | i need sub(s) and an amp. i want sql and i have a ho alternator. i can spend 700 at the very most |
Silver Member Username: GoatinU.S.A Post Number: 747 Registered: Jan-06 | https://www.ecoustics.com/electronics/forum/car-audio/215885.html |
Silver Member Username: CtmikeCt. Post Number: 231 Registered: Feb-06 | 2 type r's $114.99each http://carstereoexpo.com/swal12tysesu1.html kicker amp $439.99 http://carstereoexpo.com/kxki1chcaram1.html total $669.97 i have the same setup and was happy with it, but definately go ported. |
Silver Member Username: Gavbo211IL US Post Number: 196 Registered: Jan-05 | 2 JL Audio 12w3v2's $360 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2897 Orion 600D $230 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13470 puts you at $590. not only does taht keep you under budget, but leaves you some money for a nice wiring kit from knukonceptz such as http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6451 Registered: Jul-05 | 2 Crystal COMP 12 $239.00 per 1 Hifonics 1606?? around $200 on ebay, this would kill both of those systems they said up there |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6452 Registered: Jul-05 | 2 rl-p $239 per with the same amp |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 761 Registered: Oct-05 | yea it would. i love those crystal comps |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 762 Registered: Oct-05 | http://www.uscaraudio.com/cgi-bin/usstore.cgi?user_action=detail&catalogno=COMP1 2 then i would get a 1200.1 or like chaucey said, a hifonics 1606 |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3581 Registered: Oct-05 | 2 kicker cvr's and a kicker kx1200.1 that system will be loud in and sound decent. it would also give you some $$$$$$ left over in case you want to take some pretty beeatch out to dinner. lol. |
Silver Member Username: Sw9152Michigan Post Number: 309 Registered: Feb-06 | 4 12" cvr's and 2 audiobahn a8000t's. |
Silver Member Username: Buddyleee5Post Number: 191 Registered: May-05 | i have 2 re se's for $300 if your interested. They are brand new |
