What is another type of materal to make a box out of that sounds good besides wood?
Username: Zepcoe
TN Us
Post Number: 51
I want to make a box to fit my trunk like this Upload (i have a explorer 2 dr) what are some other materals used to make boxes besides wood that will sound good?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 840
just use wood and cover it all with carpet, vinyl, or both. you can add clear or colored plexi over the wood to give it that plastic look if you really want.
Username: Jmloughrey
Farmington, CT
Post Number: 1477
use MDF...
