Username: Anthony1 Post Number: 47 Registered: Feb-06
Tuesday, April 11, 2006 - 02:49 GMT Theoretically, which would be louder two 12's dvc wired at 4ohms receiving 350 wrms each or one 15 dvc wired for 2ohms given 1000 wrms?
Username: Lexuscoop Post Number: 1307 Registered: Dec-05
Tuesday, April 11, 2006 - 03:08 GMT why would you wire 2 DVC to 4 ohms?
Username: Anthony1 Post Number: 48 Registered: Feb-06
Tuesday, April 11, 2006 - 03:21 GMT the amp isn't 1ohm stable,sorry if that wasnt clear but the 12's would be wired like this and the one 15 would be wired like this
Username: Ucfsaxman Oviedo/orlando,
Fl
Post Number: 727 Registered: May-05
Tuesday, April 11, 2006 - 03:49 GMT depends on the subs maybe w/ the right enclosure the 15 again depending on the brand.
Username: Lewass Boomfield Hills,
MI
Post Number: 604 Registered: Jan-06
Tuesday, April 11, 2006 - 16:41 GMT Should be very comparable either way..
MI
Post Number: 605 Registered: Jan-06
Tuesday, April 11, 2006 - 16:48 GMT Everyone respects the power of two good 12's, but my respect goes to the power of the 15! Assuming your box doesn't need to be 10 cubes, lol. The way I see it, total box size is a very important factor. One sub with monster output in a relatively small box, is MUCH more impressive than lots of subs filling up the trunk. What's the point of having just one sub if the box takes up the whole trunk anyways... Stealth ftw.
MI
Post Number: 606 Registered: Jan-06
Tuesday, April 11, 2006 - 16:49 GMT Treo 15's are said to do very well with relatively small boxes...
Username: Anthony1 Post Number: 49 Registered: Feb-06
Tuesday, April 11, 2006 - 21:22 GMT So do you all think they will be relatively close? The 12's and 15 would all be type R.
Username: Anthony1 Post Number: 50 Registered: Feb-06
Tuesday, April 11, 2006 - 22:34 GMT bump
Username: Anthony1 Post Number: 51 Registered: Feb-06
Tuesday, April 11, 2006 - 23:44 GMT bump
Fl
Post Number: 728 Registered: May-05
Wednesday, April 12, 2006 - 01:48 GMT probably the 12's would be louder then.
Username: Killswitchjd Post Number: 11 Registered: Apr-06
Wednesday, April 12, 2006 - 01:51 GMT I say the one 15... just because of power issues, 1000 watts vs. 700 watts. Check out my pics in the bragging area (only accessible through the pulldown top menu under forum, then car audio...
