New member Username: KkshPost Number: 2 Registered: Mar-06 | Hi, I've just purchased an PXP02 Ipod interface and it charges and plays through my Pioneer DEH-P580MP but I can't control it through the head unit's controls. Is there anything that I've over looked? I've got a 6GB Ipod Mini by the way. |
Silver Member Username: Infinity_addictSanta Rosa, California USA Post Number: 249 Registered: Jul-05 | is it supposed to be compatible with that specific pioneer model head unit? rtm(read the manual)? |
New member Username: KkshPost Number: 3 Registered: Mar-06 | Well, it is suppose to work with the OEM CD-IB100 Ipod adaptor by pioneer. The cable I got should work in the same way albeit from a different manufacturer. I've shot them an email but havne't got a reply yet. |
Bronze Member Username: DkchillinVermont Post Number: 42 Registered: Mar-05 | I couldn't find a whole lot of info on that cable, where did you get it? From what I could tell, it doesn't look like it allows for interface with the HU, just charging and playback. I have the standard Pioneer version of that deck (deh-p5800mp) and I've always thought deck controls for the iPod were over rated, I just use the PIE PIO/P-RCA Adapter. This was the only site I could find with any info on the PXP02, and it doesn't mention HU control interface: http://www.installer-data.com/item/display_item.php?it=pxp02 |
Gold Member Username: TjmutlowPost Number: 1880 Registered: Sep-05 | that radio has limited control and features with even the pioneer piece, you have to see owners manual for what it will actually control with the headunit. |
New member Username: KkshPost Number: 4 Registered: Mar-06 | The sh1tty thing is that it didn't come with a manual. I got it off some site on the net. Well, i'll just have to think of it as an input and charger and not as a controller. Thanks for all your help. |
