System down
Username: Woofy
Post Number: 18
Hey guy's..running a cool*at 5000 with 120 norw..dn.
everything was fine since mid march..just had a bit of wet snow here in peterborough ontario, now have lost all..went to menu dish settings and there is no signal on either 110 or 119.all settings are the way i had them originally.dish is on the roof..looks clear from the ground..maybe it has moved a bit i dunno..any suggestions would be good..don't really wanna do any roof climbing if i can help it.
help if you can please.
Username: Lklives
Post Number: 1834
Reboot the receiver...BACK of receiver,power off,wait 2 minutes, power on, turn to a good channel..
If no switch on back, then unplug for 5 minutes..
Username: Woofy
Post Number: 19
Hey LK.. thanks for the info..helpfull as usual..did what you said,but still no channels..i do get a green bar while on the channels but none show up..when i go into menu my signal on both 110 and 119 are stillin the red..after i rebooted i noticed my time had gone to 2004..changed back to present time..but still the same..any other ideas Lk.
Username: Woofy
Post Number: 20
Sorry,,i should have mentioned that is just displays...no..or bad signal..while trying to view a channel.
Username: Fruitcakes
Post Number: 57
yea, really helpfull...even a fcuking retard knows to reboot the reciever when there is a problem....maybe you should switch to cable Rob, you sound like a dumb fcuking idiot..ROTF
Username: Woofy
Post Number: 21
Oh and..what do you mean by a good channel? i don't have any that's the prob LK.
Username: Warthog
Post Number: 53
Could be a million things...bad hardware is where to start...process of elimination..you don't say how problem came about..after DST?...snowstorm?...new bin? etc..
Username: Woofy
Post Number: 22
Well..new 5000 in mid march..newest bin 120..had a bit of wet snow ..nothin serious...channels started fading then just disappeared..settings are correct..after reboot on certain channels i get a hit like it want to come on..mostly green stripes and stuff..everything is brand new..hardware...cable..switch..4 weeks max..help if you can ask want you need to know..i am all ears.
Username: The_wank_artist
Post Number: 31
Check the dish and lnb for snow coverage?
reason being "channels started fading then just disappeared".
Username: Woofy
Post Number: 23
thanks man..but i was trying to avoid crawling out on the roof tonight...i do appreciate you input. thank god for cable back up..watching jays vs rays..
Username: A10
they sell protectors for the snow and weather...Go Tampa!
Username: Woofy
Post Number: 24
Ok..well i guess it was the weather..back to normal after the sun melted the snow..
thanks warthog and wanker.
oh yea fruitcakes! with a name like that who is the dumb fn idiot!
go jays!
