New member Username: BeppegPost Number: 1 Registered: Mar-06 | I have just purchase a 4 Quad 21l + 1 Quad center to use as home theater. Is anybody able to advise me on which amplifier to use? Thanks in advance! |
Bronze Member Username: RavbainsMelbourneAustralia Post Number: 14 Registered: Mar-06 | Hi Giuseppe, nice speakers!! I have never heard the Quad L series, but they certainly look very pretty (nice cabinet finishes and impressive carbon weave drivers). I don't know what your budget is, and in fact I don't know much about HT amps at all, but my friends tell me that Denon make good home theatre amps. Here is one from my local dealer, but it seems a bit expensive. But since you have the Quad's I figure you are a man with deep pockets ;-) http://www.carltonaudiovisual.com.au/?q=node/view/433 cheers Rav |
New member Username: BeppegPost Number: 2 Registered: Mar-06 | Thank you Rav for your reply. I am very happy with the Quad, as they sound very well, and they are also a very nice piece of furniture with thier "piano" finishing. I also heard that Denon has a very good reputation, and I very like the model you suggested me. In fact, I am not able to choose between the AVR 3806 and the Onkyo TX-SR803E. Is anybody able to help me? PS. I wish I had deep pockets, so that I would not have to warry about making a mistake! |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 767 Registered: Dec-03 | giuseppe: I would opt for the Marantz SR7500 if I could afford it, the Marantz SR5600 if I could not. I would also look into the Cambridge Azur 540R receiver, as well for those speakers. I hope this helps. |
