Bronze Member Username: Shredmaster1013Post Number: 37 Registered: Feb-06 | Can someone find me a cheap 4 channel amp to hook up to 4 6x8 kole 3-way 180 watt speakers? Will the amp add bass to the speakers? Or will it just make them play louder? |
Gold Member Username: RovinTrinidad & T... Post Number: 7131 Registered: Jul-05 | um - what real kinda do u expect out of 6x8s speakers ! if u have 4 of those i'm guessing on ur rear dash cause u dont want subs do 2 space , get rid of those & instead go with 4 8s free air if space is a issue in ur ride or get 1 good 10" in ur trunk........ |
Bronze Member Username: MakmillionUnited States Post Number: 36 Registered: Apr-06 | Pick a better brand too, Kole is great if you want their subs or amps.. even a bass cap.. but their speakers blow way too quick. In case you stick with them, though: http://www.justamps.com/Amp_Pages/kole/kole_kx.htm |
Bronze Member Username: Shredmaster1013Post Number: 39 Registered: Feb-06 | Which amp would I get? How many watts? |
Silver Member Username: Extrmndor3Chicago, Ill Us Post Number: 334 Registered: Feb-06 | phoenix gold octane r 4 channel the 800 wattts model i just installed in my ford explorer with my octane r z rated components and polk audio 2 way speakers for the back and it sound awesome bty the amp is like 200 and the components i bought it for 80 bucks at etronics.com and it sounds really clear |
Gold Member Username: RovinTrinidad & T... Post Number: 7152 Registered: Jul-05 | if i'm not mistaken KOLE is made by POWER ACOUSTIK - so that should say something in ur choice ...... |
