New member Username: Renegade4evaPost Number: 1 Registered: Apr-06 | hey guys, i just bought an SWR 1241D 12" sub, my first time trying to set up a system. i dunno what amp will be the best sound. specs 300W RMS 1000W peak. 4+4 ohms. dual i keep on seeing peeps saying u can turn this into 2ohms, but i can't work out how, any help or suggestions will be great. tanks |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 1656 Registered: Feb-05 | to wire that sub up at 2 ohms, you need to wire the VC's in parallel. hook the Positives and negitives together. then hook the amp up to either VC. http://mobile.jlaudio.com/support_pages.php?page_id=161 first pic on the right. |
Silver Member Username: Goose5714Post Number: 435 Registered: Feb-06 | don't r's have a higher rms than that? |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 344 Registered: Dec-05 | 500w rms |
Silver Member Username: Graphix1Santa Rosa Heights, Arima Trinidad & T... Post Number: 845 Registered: Oct-05 | yea,im sure you can give it alot more though... |
Silver Member Username: DjbeanpoleNaptown, Indiana USA Post Number: 136 Registered: Nov-05 | Of course you can give a Type-R more power! I have 2 and I'm running them each at 600W!!! An option for you is that I have an Alpine MRD-M500 sitting around, 500W, if need be... but you can give them more than that and they will love it. |
Silver Member Username: GagePost Number: 107 Registered: Feb-06 | no the older 1241 and 1221s have a rms of 300 the 1242 and the 1222s have 500rms its the v1 and v2 of the alpine subs |
Silver Member Username: DjbeanpoleNaptown, Indiana USA Post Number: 138 Registered: Nov-05 | Whoops I looked over that I just saw Type-R, good call Gage. |
New member Username: Renegade4evaPost Number: 2 Registered: Apr-06 | so i can just get an MRD-300. then wire it up in parrallel? and it'll be sweet? |
Silver Member Username: LbecknerTulsa, Ok Usa Post Number: 923 Registered: Oct-04 | yeah, you need an amp that can be wired down to two ohm, not one ohm. If you get one thats 1 ohm stable then u will need a 600 watt amp to get 300 watts. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 350 Registered: Dec-05 | if you wire them at 1 ohm, you can buy directed 600d or orion |
Silver Member Username: LbecknerTulsa, Ok Usa Post Number: 957 Registered: Oct-04 | You should get a 300 watt Lanzar amp, but becareful it may blow that sub cause it puts out more lik 1000 watts. Probably to be safe you should get the Lanzar 50 watt. |
Gold Member Username: RovinTrinidad & T... Post Number: 7240 Registered: Jul-05 | better u buy a JL 500/1 check another thread in this amp section cause a guy has 2 of them selling ........ |
