Silver Member Username: RmzracerBentonville, Arkansas USA Post Number: 122 Registered: Jul-05 | Tell me what you think of this box for my truck. Right now I have a sealed box with just about the same dimensions. I have 2 12" type R and a Mb Quart Raa1000. It pounds right now but do you think this would get it louder with a ported box? and is 35 hertz about right? Its going in a single cab dodge truck. http://www.accelerator-pedal.com/ported-box.asp?Ew=59&Eh=19&Dia=6&Xmax=4&Vd=.84& NumW=2&Vb=3.7&Fb=35&Qts=&Vas=&Fs=&CE=0 |
Gold Member Username: RovinTrinidad & T... Post Number: 7123 Registered: Jul-05 | i too have 2 Rs & same MB amp y r some of ur specs off like 4mm xmax ? - do u have a spec sheet ? , use values found on ur spec sheet ..... |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2675 Registered: Mar-04 | if you are doing a vented box in a single cab truck...try subs firing into your back w/ port low on the box firing into the passenger side wall (at least 3" away from the wall). if you cant get it to work right like that...try a port in the center firing up. |
Silver Member Username: RmzracerBentonville, Arkansas USA Post Number: 124 Registered: Jul-05 | what are the specs on the subs? i dont know where my sheet is. I read somewhere that it was 4mm. or can i download one? |
Silver Member Username: RmzracerBentonville, Arkansas USA Post Number: 125 Registered: Jul-05 | hows this one look? should be proper specs. http://www.accelerator-pedal.com/ported-box.asp?Ew=58&Eh=19&Dia=6&Xmax=14&Vd=.16 3&NumW=2&Vb=3.2&Fb=31.06&Qts=.43&Vas=2.048&Fs=28&CE=1.5 |
Gold Member Username: RovinTrinidad & T... Post Number: 7150 Registered: Jul-05 | i'm not box expert but i'm currently using that same prog 2 figure out a box 4 my needs some of ur nos r still off - its >>>>> xmax = 18.2mm sub displacement = 0.071 cuft net internal volume = 1.3cuft how did u pick 31.06hz as the freq ? - thats odd that lenght sounds really long - im guessing thats how wide inside ur truck is !? ..... |
