2004 Oldsmobile Alero New Head Unit Installation PLZ Help
Username: B_t_33
I own a 2004 Oldsmobile Alero and i recently got a new cd player for it and the kit i got says im suppose to wire the old factory deck in my trunk. the problem is that there is these two black blocks that look like they plug into something but i dont know what and when i hook it up the factory deck turns on but my new head unit doesnt. if you know whats going on plz let me know i have been trying to figure it out for weeks. thanks
Username: Makmillion
United States
Post Number: 10
I don't understand...
.. This intrigues me, do go on to explain your situation, feel free to PM.
Username: Tjmutlow
Post Number: 1849
they make a harness that goes behind the radio, that is an old harness style and is the cheaper way to go, check circuit city or crutchfield. it is a gm databus wiring harness, around $80
Username: Dkchillin
Vermont
Post Number: 33
I know you have an Alero, but you may want to look around the Grand Am forums since they're basically the same car. Try here:
http://www.gaownersclub.com/forum/forumdisplay.php?s=&forumid=9
