ok i got my system hooked up 1 re sx 15 wit a 1000 watt rms amp hooked up to 1 ohm i love the sq and all that but i want to upgrade my interior speakers what do uo recommend????
i recommend you some CDT component sets or Rainbow if you can afford it, if you want to go cheap i'll say cerwin vega, infinity or mb quart, and buy a nice amp at least 200w rms at 4 ohm
well i was thinkning of using this old amp i bought for 5 dollars to run some 6x9's or something(xplod 250watt) im using JL AUDIO 1000/1 1000 WATT RMS MONOBLOCK to run the sx i spent alotttt of money on it
Whats a good set of components for around 200. Also what would be the main difference between those and just some 100 dollar coaxils. would the extra 100 dollars really make enough of a difference?
