Kicker solobaric l7
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 72
Is two 15" kicker l7 solo barics really worth the money compared to two 15" comp vrs? DO solo barics really hit that hard for the money if i put two 15 inches on a 1000 watt memphis amp?
Los Angeles, CA USA
Post Number: 3471
if that is the amp you are using then i would go with the 2 15 cvr's
Username: Rovin
Trinidad & T...
Post Number: 7080
yup !^^^^^^^^^..........
H-TOWN, TEXAS US
Post Number: 73
if i got the two comp vrs i am going to use a planet audio p-850 to push them!! But if i go with solobarics im getting the memphis.
Los Angeles, CA USA
Post Number: 3474
why not go with the memphis for the cvr's? that memphis isn't enough for 2 L7s anyways.
H-TOWN, TEXAS US
Post Number: 74
it is because with the cvrs the dude told me i gotta keep da gain down so i wont br getting all the power. ANd my friend have the solobaric setup and it pounds.
H-TOWN, TEXAS US
Post Number: 75
No IDEAS?????????
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2645
go w/ two DVC 4ohm CVR 15's and the memphis amp...that will be match. (cvr 15's are 500wrms)
if you have the room, go w/ a ~7-9cuft ported box tuned to 32-36hz. (70-90sq inches of port)
H-TOWN, TEXAS US
Post Number: 76
i really want a sealed box and no ported
Username: Kevin420
Gilbert, Az USA
Solo's kick butt in my opinion. I have a S12L5 powered by a kicker 600.1 and it rocks. But maybe 2 L7's down the road might be replacing the single L5. When is enough, enough anyways???
