Ok, i have some edead and i have been waiting since christmas to get it put in, and its finally warm enough.. i think. What is the temperature you should paint on edead at? its the v3 kind. Also, what should i use to paint it on with.. a brush of some kind with bristles, or should i use some kind of roller? Does anyone know sites with step by step instructions? that would be great!
If it still gets cold at night, can i paint it on and wait more than a day for it to dry, then put on another coat? im guessing it takes longer to dry in colder temperatures.
does anyone have any tips for me? i haven't done this before and im not sure how to get the best results. I might do this tomorrow if i have time and dont need my car for a while.
