Just a question
Username: Analman_returns
Post Number: 200
what is the difference between a mikobu 1 and a mikobu 111
Username: Lklives
Post Number: 1632
Post Number: 201
all sh8t aside can you help. LK
Username: Lklives
Post Number: 1634
They are both old loaders/unloopers for DTV cards..difference is probably minimal..probably some slight improvement in case design or fixed dac settings..without having them side by side and disecting them, there is no way to remember the EXACT differences..what the hell difference does it make..no good now for anything....unless U want to mod a Mik 3 into an iso..
Username: Terbok
Lk, which FTA receiver would you suggest to some one just starting out with FTA's?
Username: Lklives
Post Number: 1637
Depends upon their finances..Pansat 3500 or Coo*lsat 5000 are reasonable and very good..
Username: Terbok
I did a search to determine the difference between the cool*sat 5000 and the cool*sat 6000 but was unable to find anything other than one is new than the other. Which would you recommend between the two? Your help is greatly appreciated.
Post Number: 202
can you make a mik 1 an iso loader
Username: Cincy
Post Number: 17
HI JOE
I have c**lsat 5000 plat.
It has good guide and works well so far.
Had it about a month.
Info. is some what easy to get for it.
Post Number: 204
is my mikobo 1 any good or should i scrap it?
Username: Terbok
thanks you for all you help alan engle
Username: Lklives
Post Number: 1710
scrap the Mik
Post Number: 205
i ask the guy that i got it from he says its a mikobu i, and its an iso loader is this true
Post Number: 206
this is the one i got any good
The Mikobu ISO Programmer is the best device on the market supporting both the 3.56MHz and the 3.68MHz crystals. This unit is the most advanced of its kind. its made from the highest quality boards and the most superior technology.
Product Features
* True universal ISO-7816 Compatibility
* Dual Crystal support for Dish Network
* Can be powered by the PS/2 port - Great for laptops.
* In a custom built Protective Case
* Designed by MIKOBU, one of the most respected names in the DSS industry
Username: Lklives
Post Number: 1764
If this is true, then U should be testing DN plastic..yes that is very good..
Post Number: 208
where can i get software
Username: Wakenbake
Post Number: 14
you ask the guy
a,,hole
Username: Lklives
Post Number: 1767
Ecoustics...ban this clown wakenbake...all his posts are negative and trouble...he's kneegrows or his cousin!....If U are a mod, then START doing your job!
Post Number: 209
LK where can i get software?
Username: Wakenbake
Post Number: 15
lk ,then keep on entertaining mr.ana1
Username: Cincy
Post Number: 32
wakenbake
nothing better to do than pester people.
please go away
Username: Wakenbake
Post Number: 16
answer the thread or STFU
U have nothing to offer
