Username: Bigherm78 Monmouth,
Or
Usa
Post Number: 28 Registered: Oct-05
Wednesday, April 05, 2006 - 08:34 GMT is a sony xplod 1200 watt amp better than a phoenix didgital 1200 watt one and what size ground and battery wire should i use
Username: Makmillion United States
Post Number: 17 Registered: Apr-06
Wednesday, April 05, 2006 - 08:44 GMT pg is the better choice. shy away from sony! you should use 4 gauge power/ground wire with the pg, not sure with the sony on account of I doubt it would ever use 1200, or even 600, watts of power.
Username: Tjmutlow Post Number: 1859 Registered: Sep-05
Wednesday, April 05, 2006 - 10:13 GMT the sony
