Hey!!! Solobaric Guys
Username: Kevin420
Gilbert, Az USA
Post Number: 7
I have a 12L5, Thinking of changing to an L7. I have the preloaded kicker enclosure, the catalog shows same cu. ft dims. Think my 600.1can run an L7??? 600 rms, 1200 peak watts?? Is there that big of a diff. between L5, and the L7???
Username: Ctmike
Ct.
Post Number: 174
not the biggest kicker fan, they are good for straight spl though, but from what i hear/heard the l5 is better than the l7. not quite as loud but better sq (as far as kicker sq goes).
is that your amps specs? i'm pretty sure the l7 rms is something like 700w, so you'd need a bigger amp in that case.
Username: Jesse2055
hey i got 2 clarion 1000 watt 500 rms 12" subs, i wanna know what is the best amp to power these 2 units, ( mono or 2 channel) and how many watts??
Username: Ctmike
Ct.
Post Number: 176
what's the voice coils on them and your budget?
you really shouldn't be thread jackin neither, next time start a new one.
Username: Kevin420
Gilbert, Az USA
Post Number: 16
Good call ctmike.No jack moves... Any sub you think might out do the L5 using the same amp?? Always open for better bass!!
Username: Fandim
Reno, Nevada United State...
Post Number: 858
using the same amount of power, a L7 will sound nearly identical to a L5.
